Guys,I hope you can help! I've got a 70ish JD 110 8 HP Kohler. There is something wrong with the clutch because if it is not pressed in the perfect spot, you get no response when starting. Once the pedal is pressed perfectly (which may take up to 50+ times), the tractor starts perfect. I have been ignoring this for a few weeks, just being patient as I start it, well, today I couldn't get it to go at all. Is there a clutch safety switch? Is there anything electrical about the clutch? Also, the safety that is attached to the gear shift has been bypassed and disconnected long ago, so it cannot be this. It must be the clutch. Currently, I've got the battery, battery plate, and other guards taken off so I can see much of the clutch linkage and I cannot figure out what to look at to either adjust or replace. Any help would be greatly appreciated. Thanks! Hoff PS: At first I figured that there must be a wire or something that is just old and in need of replacement somewhere on the clutch linkage which is why it won't start, but I don't see any! Am I looking in the wrong place?
