730 wiring and light troubles
Deereboy
06-10-2006 18:34:27
I've got a 1959 730 D electric start (2 12 volt batteries) that I recently put fenders and 4 headlights on. The rear light works as it should, but the front lights don't work at all when the switch is in the "D" position (the last one). From my understanding, the two outside lights should be on. I've wired the lights according to the diagram in the parts book, but after searching the archives here it sounds like I need a wiring going from the batteries to the seat box to ground them. I don't have this wire and the existing wiring is a mess. So if anyone has a diagram they could send me for 2 12 V batteries or tell me where the ground wire should be put in since the parts book only shows 4 6 volt batteries, that would be great. Also, if you have any suggestions on why my lights don't work in the "D" position, that would also be great. Thanks in advance for any help.
johns48b
06-11-2006 05:38:24
 Re: 730 wiring and light troubles in reply to Deereboy, 06-10-2006 18:34:27
did you use new bulbs or old ones? i'd get a jumper wire and run to the lights to see if they work. if they don't work try running a second wire to the lights for a ground. if that works you may not have a good ground fron fenders to frame. only other thing i can think of would be to replace switch. john t will be of more help when it gets on line here. you didn't happen to use 6 volts bulbs and blow them did you? good luck
Deereboy
06-11-2006 06:40:25
 Re: 730 wiring and light troubles in reply to johns48b, 06-11-2006 05:38:24
I bought rebuilt lights that have 12 v sealed beam light bulbs. When the switch is in the other 2 positions for the lights, "L" and "B" I believe, all four lights on the front work. The two inside ones get brighter on "B" like they should. It's when the switch is on "D" and only the outside lights should be on that nothing happens. I've tried running a wiring to ground them to rule out a bad ground. I am wondering myself if it is the switch, but thought I'd check here first to see what there was to be said about the lack of the ground for the batteries.
Glen in TX
06-11-2006 13:00:25
 Re: 730 wiring and light troubles in reply to Deereboy, 06-11-2006 06:40:25
Sounds like the switch since others are bright and those switches are known to go bad. Never hurts to have a better ground though. Make sure you are using good cables or new ones with good connections. If you need a wiring diagram let me know. This link sells some nice wiring harnesses.
jcee
06-13-2006 05:03:20
 Re: 730 wiring and light troubles in reply to Glen in TX, 06-11-2006 13:00:25
chances are it is the combo switch, as suggested. at the combo switch you can change around the non-working light connections to the working light connections to test your switch. i just rewired my 2 730s and had the same problem with the combo, however mine are only double hdl's. the ground to battery box is very imporant, it should split the 2 batteries, or split the 4- 6 volts, mine are 4 - 6ers. good luck.
Deereboy
06-13-2006 18:43:45
 Re: 730 wiring and light troubles in reply to jcee, 06-13-2006 05:03:20
Thanks for you help guys. I added the ground from the batteries to the battery box and that made the lights work in the last position as well as make the lights work better in the other positions. It"s amazing what happens to these tractors over the years. I guess that ground wasn"t thought to be important at some point by a previous owner.
