I think part of the problem is you have to separate fact from emotion and fiction. Often, when somebody hates something - they have NOTHING good to say, regardless of fact. To the converse, just because your tractor serves you well - it does not disprove or negate some negative claims against the 1010 and 2010 series. I worked on many 1010s and 2010s when new. It was, beyond any logical doubt, a low point for Deere Company - when put into the reference frame of other Deere tractors. But, that being said - they can still be useful, and moderately reliable tractors. I still have two. Before the 1010s and 2010s came out, many of old-timers were griping about the Deere H ag. tractor being an "outcast" because of it's inaccessable brakes, 1/2 engine speed belt pulley, etc. Once the 1010 and 2010s arived, I rarely heard the H mentioned. Deere had its "bad day" with the 1010/2010 series just as Ford did with its Selecto-Speed transmission. But at least with Ford, they completely redesigned the trans. and fixed it ( and I suspect Deere copied it for their Powershift). A few facts with 1010s and 2010s. Wheel tractors NEVER had adequate brakes for safe use on hills with a load attached. We went nuts trying to fix, update, modify, etc. Sleeves and seals. Deere never used the siamese sleeve design with any other series, and to my knowledge, no aftermarket company has ever made sleeves. So, you are stuck buying from Deere Company at an elevated price. This has no effect on engine durability or reliablity except for the single seal per cylinder. After Deere discontinued the sleeve-deck design, and went to individual sleeves in the 350 and 450 crawlers, 2020 ag. tractors, 440 skidders, etc. the single seal design was still used and had a failure rate equal to the 1010s and 2010s. But . . . after many premature coolant-into-oil leakage problems, Deere updated the sleeve design for all the old engines - EXCEPT - for the 1010/2010s. So, they can run quite well but will never have the "average" longevity of the later engines - which is not necessariy a big deal. And, parts will ALWAYS cost more for the 1010s/2010s - unless some company decides to produce replacement parts. Hydraulics on ag. tractors including main hydraulics, power steering, etc. I could write volumes on this, but I won't. It has always apeared to me that Deere threw these systems together with "left over" parts that they needed to get rid of. Will they work when they work? - yes. Are they reliable when compared to earlier or later tractors - no. Can you get new parts, or substitute other parts as easily as earlier or later tractors - absolutely not. If you have some facts that differ with mine, I'd like to hear them. I must admit, that after many years working for Deere dealerships - we mostly got to hear about, and see, the problem tractors. If we sold a good one - the owner did NOT make frequent visits to our shop to tell us how much he loved his tractor. Also, Deere had many production problems with later tractors. We had starting and smoking problems with the 40 series ag. tractors, we had 50 series 4WD tractors that had the WRONG gears driving the front axle - i.e. the front wheels went MUCH faster thant the rear, there was a class action law-suit against Deere for every HL-R transmission they ever installed into a 2010 or 450 crawler, etc. But - Deere fixed those issues. With the 1010s and 2010s - in my opinion - they made a few minor updates - and then cut their losses and moved on - thus - in a way - short-changing people who had bought them.
