JD 300 Garden tractor running issues
Sitka
06-10-2006 11:20:13
I recently purchased a JD 300 garden tractor, and it has running issues. The engine is the original 16hp Kohler. The engine stutters and hesitates as the throttle is increased or when the tractor is subjected to a load. If the throttle is raised extremely slow, it will eventually go to full RPM's. However if it is done too quickly (or if the load is not reduced) the tractor will quicly start to stutter and never really recover from it. Here is what I have done with no success: replace and set the points, replace and gap the plug, Removed and thouroghly cleaned the carb and all of the passages. I also adjusted the carburator for optimum performance (seemed to help a little). Any help would be appreciated as the engine idles good and it seems to be powerfull with no strange noises or excess smoke.
Roger in Iowa
06-10-2006 11:39:35
 Re: JD 300 Garden tractor running issues in reply to Sitka, 06-10-2006 11:20:13
Try richening the mixture on the idle and main jets 1/8 turn out. Might even try 1/4 turn on the main jet.
Is the air filter clean? New?
Have you replaced the condensor with the points?
If all else fails, replace the coil or try another.
I have a 300 and 316 with the Kohler without surging. Dad's 300 surged when the throttle was advanced, but richening the main stopped that.
Roger in Iowa
