4010 tach cable
jc mini
06-10-2006 00:08:43
I have A 4010 that I just bought and some of the sheet metal was taken off. it all came with the tractor but were the tach cable goes in next to
the injecter pump there is a plug that sticks out
twords the side panel it looks like a place to adjust the pump .It is in the plate that bolts below and to the side were the injecter pump bolts and the tach cable screws in to the top of this plate ,but the plug it has in it now is about two inches long so I can't put my side panel on .Is this a special fitting can this plug be replaced with a shorter plug and what is this A acess To
Im new to john deere so please help . Thank You
P.S This is a great web site!!!!!
MSM
06-10-2006 05:40:15
 Re: 4010 tach cable in reply to jc mini, 06-10-2006 00:08:43
The "correct side panel" has a hole punched in it to clear the jam nut.Just measure yours up and drill a hole in it.
ET
06-10-2006 04:02:53
Under that tall nut is the engine oil presure ajusting screw.
