8440 vs 4850
DICK68
06-09-2006 23:33:37
As a JD enthusiast I have always had thirst for powerful and big tractors (I don't farm but have them for my hobby). I had almost samples of all the series (4020, 4520,5020,4630,4440, 4640) and one year ago acquired a 4WD 4850. Now I would have an opportunity to trade the 4850 for a articulated 8440 which from an HP point of view is very close to the 4850. Could someone tell me if they'd do the trade ? I know the 8440 is more impressive in size but my worry is : Is this machine not a bit sluggish (heavy weight and small size engine) ? Unfortunately 8640s have not been sold over here.
G/MAN
06-12-2006 13:25:35
 Re: 8440 vs 4850 in reply to DICK68, 06-09-2006 23:33:37
Unless the 8440 has a PTO and 3-point hitch, I wouldn't even consider giving up the 4850 for it.
johns48b
06-10-2006 17:52:54
its to bad that you can't get an 8640. i worked for a man in n al that row cropped 6000 acres. he had an 8630 and a 8640. both were real good machines. the engine came out of the 8630 after i had been pulling 7 - 20 inch flatbottoms for 3 weeks with it. i went down in a ditch and came out the otherside and it with ret-a-tat-tat and that was it. it turned out that jd had misdrilled the oil jounrnal on one throw and they made the engine up at no charge. the only problem i ever had driving the 8640 was when the bolts came out of the coupler holding the crank to the pto pump. they just came out and didn't go through the radiator, but i was at the end of a through and started to turn before i ran into the woods and no power steering, no clutch, no nothing. i killed the engine and kicked it out of gear and started it right back up to keep from frying the turbo. we found the two halves and a few bolts later i was gone again. if you really want to play with some big horse power get a stiger panther. we pulled 8 - 22 inch flat bottoms in river bottom soil and a 33 ft rome disk with dirt running across the axles with it. i'd be surprised if some area farmer wouldn't let you take your tractors and do some tillage work of some kind for him. he'd probably furnish the diesel and you could spend a day having a ball. only thing is, you'd quit your day job. good luck if you decide to trade.
