2640 hydraulics heating
flatbroke farm
06-09-2006 18:56:20
2640 hydraulics overheating, it is not the SCV's, and I can see through the filler cap/hole that the oil is moving at the bottom of the case (needed a good light), what is this telling me, if it was the rockshaft system would this cause oil movement at the bottom of the case? Sometimes I can detect a mist of oil in the case but cannot see any oil coming from the rockshaft piston. Any suggestions would be appreciated.
Tx Jim
06-10-2006 03:59:28
 Re: 2640 hydraulics heating in reply to flatbroke farm, 06-09-2006 18:56:20
If you see a mist in hyd filler hole it is my experience that rockshaft valves are leaking. RC housing will have to be removed to get to valves. Tx Jim
MSM
06-10-2006 01:11:12
If the rockshaft valving or piston were leaking the housing itself will become warm to the touch after about 10-15 minutes running time. If you are seeing a mist I would venture a guess of a split,or broken hydraulic line,blown o-ring etc in or under the rockshaft housing.
