For 2010 haters...
Bob
06-09-2006 12:54:52
Here's a pathetic example (cosmetically) of a 2010 diesel, in the shop for 3-point hitch repairs.
Third Party Image
As I posted previously, the remains of a "garter spring" from an oil seal somewhere in the hydraulic pump or transmission found their way into on of the rockshaft control valves.
I have always defended these little guys as not being QUITE as unreliable as their "rep", we'll see if that opinion holds when I get the 3-points back together and working!
Loren NC
06-10-2006 04:00:55
 I am not a 2010 hater..... in reply to Bob, 06-09-2006 12:54:52
.....in fact my opinion of them comes straight from the local dealer's mouth. He said, "The only thing worse than a 1010 or 2010 gas tractor is either one of them with diesel." I learned that right AFTER I bought my 1010 gas at an auction. But let me think.....still running after 43 years.....hmmmmm ! We have farmers who don't last that long!
mark ace
06-09-2006 20:04:44
 Re: For 2010 haters... in reply to Bob, 06-09-2006 12:54:52
my dad had a 2010 gas & diesel, i had no respect for either one!! how about the crawlers, were they as bad?
zwr
06-09-2006 19:54:00
The one I had lived up to its (by now)reputation. It was a rattle trap from head to toe. Transmission, brakes, hydraulics--all "el-cheapo". But it was the sleeves in the diesel engine that finally did her in.
Mike M
06-09-2006 16:44:46
I was always told they weren't JD's best design. I have done a little work on some of them and tend to agree. I always thought they copied Farmall too closely. The steering shaft through the gas tank and radiator was my tip off.
But given the very large amount of them I see advertised and still alive and well I tend to think they weren't all that bad or else they would all be in the junk yard.
Tx Jim
06-09-2006 15:13:38
Bob,working for a JD dealer when they were new I don't hate them. I think that John Deere should have taken all of them back under the "LEMON LAW" if the law existed in the early '60's!!!!! !! I classify them as boat anchores(SP). Tx Jim
Bob
06-09-2006 15:18:37
 Re: For 2010 haters... in reply to Tx Jim, 06-09-2006 15:13:38
The guy that owns this one has had it for quite a number of years, with very little trouble. However, this is a really dumb ussue we are dealing with, now!
Tx Jim
06-09-2006 15:49:55
 Re: For 2010 haters... in reply to Bob, 06-09-2006 15:18:37
I see in picture the diesel decal so the owner is very lucky or hasn't put many hours on that little cream puff!!!!! !!!! Tx Jim
JDknut
06-09-2006 14:04:33
The gassers were not too bad, and some of the Diesels were OK. The biggest problems was with the "sleeve-and-deck" lower seals failing after all the Diesel vibration, but apparently some of them seemed to hold up better than others. Chances are if one made it this far, it is one of the "good" ones.
jdemaris
06-10-2006 06:47:32
 Re: For 2010 haters... in reply to JDknut, 06-09-2006 14:04:33
I don't believe the sleeve-deck design had anything to do with problems - other than it requires you to buy four new sleeves at once - which is usually the case in other engine rebuilds anyway. The problem was the single seal-ring which also existed in early 350s, 450s, 2020s, etc. But . . . Deere offered update "change-over" kits for the later series engines - but never bothered updating the sleeve seals in the 1010/2010 series. The update kits provide three seals instead of one, including the one orange ring that expands as soon as oil contacts it and fills gaps. I worked on the 1010s and 2010s new. In general they were pretty bad - especially the 1010s that were underpowered and the wheel tractors in general. The 1010 gas engine is basically the same size as a 420 - just has four little cylinders instead of two big ones. Wheel tractors NEVER had brakes that worked - not even when new. In my opinion, the crawlers were pretty good. They shared certain problems with the later 350s and 450s, but for the crawlers - there were MANY updated and improved parts.
