3010 Gas Compression
Steve/IA
06-09-2006 12:33:25
3010 service manual states the compression on a gas engine is 160 psi when rings are new but I can't find any where in the book that states the low limit. Mine is 110, 110, 105, 100 psi. I am getting some blow by out the vent tube but not too excessive, when should I overhaul?
Steve/IA
06-09-2006 20:30:53
 Re: 3010 Gas Compression in reply to Steve/IA, 06-09-2006 12:33:25
Yes I did have the throttle open but I did not try it with oil. I'll give it a try. It is running real good but getting a little weak at times.
G/MAN
06-09-2006 13:32:38
That's getting down there, but measured compression can vary quite a bit depending on conditions. You did have the throttle open when you did the checks and the cranking speed is up to snuff, correct? You could follow up with a "wet" test by squirting some oil in the cylinders to verify that the leakage is past the rings and not the valves. The good news in your case is that your readings are pretty consistent across the board. You don't want more than about a 10% variance from cylinder to cylinder. If the tractor still runs decent, isn't burning tons of oil and/or fouling the plugs and it doesn't make a huge cloud of blowby, I'd keep running it as long as possible.
