Help on 70 live power clutch
Lon in NE
06-09-2006 11:39:10
Yesterday was the first time that I had the need to use the live pto on my 70 gas. When I pulled up the lever to engage the PTO, nothing happened. When I used an 18" pipe wrench to turn the PTO shaft, it was stiff and I could slightly hear/feel gears turning.
Any ideas on what is wrong, and how do I fix it? TIA!! Lon
RICHARDJ
06-13-2006 07:10:57
 Re: Help on 70 live power clutch in reply to Lon in NE, 06-09-2006 11:39:10
55-50 PLEASE EXCUSE THE FLUCK OUT OF ME FOR TRYING TO BE HELPFUL. I APPARENTLY DID NOT CATCH THE PART ABOUT PULLING THE LEVER UP WHICH MEANS I DID NOT REALIZE WHAT HE HAD. AS I WAS ONLY TRYING TO BE HELPFUL AND NOT LOOKING FOR AN AS CHEWING IN THE FUTURE I WILL KEEP MY COMMENTS TO ME SELF EXCEPT FOR THIS LAST ONE. 55-50 GET FLUCKED.
RichardJ
06-09-2006 13:44:23
Instructions given were for an Engine Drive Power Shaft. Not knowing if you have the engine driven or transmission let me give you the other method:
TRANSMISSION DRIVE POWER SHAFT The transmission driven pwer shaft is started and stopped by the main clutch lever and will operate whether the tractor is moving or not. However, it will not operate unless the main clutch is engaged.
To place the power shaft in operation, stop the tractor but leave the engine running. With main clutch disengaged (clutch lever pulled to the rear), move the power shaft shift lever to the left. It may be necessary to move the clutch lever forward slightly, permitting the pulley to turn slowly. This allows the gears to line up for easy shifting."
Cluch lever in these instructions refers to the tractors clutch lever not the pto clutch lever because you do not have a pto clutch lever on a transmission driven pto.
If you have a power shaft clutch lever (the lever located on the right hand side of the sea you have an engine driven pto. no clutch lever you have a transmission drive.
55 50
06-10-2006 17:02:23
 Re: Help on 70 live power clutch in reply to RichardJ, 06-09-2006 13:44:23
Not knowing????? He said "when he pulled the lever up", that automatically means it's the engine driven PTO!
Mike M
06-09-2006 11:59:50
First thing is with the engine off engage the drive gears. There is a little lever sticking up by the shift tower this would be at your right toe when sitting in the seat. Only move this with the engine off as it is moving the gear teeth into mesh. Slight bumping of the starter may be needed to get them to mesh sometimes.
Then try your other lever on the side of the seat frame once you have it running. The reason it wouldn't turn with the wrench is that the brake is automaticly applied when the lever is down.
