620lpg starting troubles
sw in il
06-09-2006 08:54:17
I can not get my 620 lpg to start! It will run on one cyl with the intake tube off if you place your hand infront of the carb to restrict the air flow it picks up the other cyl and runs great. If you put the intake back on it wont even fire! The tank only has about 10% of fuel in it. The oil level is fine in the air cleaner. I am starting it on the vapor side. Any help would be great! Thanks
Glen in TX
06-09-2006 09:14:29
 Re: 620lpg starting troubles in reply to sw in il, 06-09-2006 08:54:17
Check and make sure the vent hole on back side of regulator/vaporizer isn't plugged with mud dobbers crud. Inspect your air cleaner and intake for the same to be sure it's clear. May also just need more fuel depending on temperature there to vaporize fuel and guage may not be correct. When you open the vapor valve or any LP valve on a LP tank just open it slowly or the excess flow valve disc on inside of valve can slam shut cutting off flow. That disc is on the inside of tank on valve to cut off flow in case a line burst and those disc seldom fail but can. If it's something like that your LP dealer should have new valves or kits or be able to get them. Take lines loose and make sure you have fuel flow to regulator and out of regulator on other end. Should only be about 8-12 oz. pressure out regulator to carb. Also make sure the governor and throttle linkage is okay and working.
