3020 western special need 3 pt.
Bill in Colo
06-08-2006 19:14:47
Have a low houred (3650) 3020 diesel western special that needs a 3pt ,has anyone added one? I may be able to purchase a junked 3020 on the cheap.
MSM
06-09-2006 08:22:18
 Re: 3020 western special need 3 pt. in reply to Bill in Colo, 06-08-2006 19:14:47
You will need the junker if your tractor does not have a rockshaft.It will have to be gutted out to get all the associated parts attached to the load control shaft in the bottom of the housing,and then you will also pretty much have to gut the rear on your standard to put in the load control shaft and lever.Just mounting the rockshaft housing on the standard won't work,the 3pt needs the load control shaft and linkage to work.Also if your standard has a swinging drawbar,that will also have to be changed to accomodate the lower 3pt arms.It's a doable job,just time consuming,and will take some new gaskets and seals.Might also be a good time to go through the synchros on the trans shaft while the tractor is apart if there are any shifting issues.
Bill in Colo
06-09-2006 11:37:15
 Re: 3020 western special need 3 pt. in reply to MSM, 06-09-2006 08:22:18
MSM,could it be used without the load control linkage as I only need position control on the the three point.
MSM
06-10-2006 01:17:09
 Re: 3020 western special need 3 pt. in reply to Bill in Colo, 06-09-2006 11:37:15
It possibly could be modified to work that way. maybe try a salvage yard for an aftermarket 3pt,like a cornhusker.Might be cheaper and easier.
