Advice on 4020 4230 4520(4430 eng)
Vern Sanders
06-08-2006 17:22:16
I need some advice on which tractor to go with. I have 60 ac with 41.5 tillable. I have a '66 3020 Gas PS with a loader and a '64 4020 D syncro with Narrow Front and no cab with probably 8-9000 hrs on it. It has 1730 hrs on a replaced tach. I used the 4020 on a IH 45 18 ft Field Cultivator this Spring. Its got 18.4x34 tires with no weight or fluid so with wings down there was quite a bit of slippage so I went with wings up which made it a 12 ft and according to tables I've seen, a Fld Cult takes 6 hp per ft so I would need 108 hp to pull the full 18 ft at 5 mph. I've had about $3000 worth of repairs done on the 4020 (injectors replaced & new hyd pump - so I already have more in it than it's worth) but it still needs the pto clutch replaced and I think the main clutch too since the rear engine seal slightly leaks oil on it and I think I could sense some clutch slipping this Spring too even at the 12 ft width.
I know of a '73 4230 Quad with SG cab for sale for $6500, but it's rated a 3 out of 10 with 7222 hrs so it may have problems already and from reading past postings on the 4230 it might not be the best tractor to put alot into to fix up since they take more fuel and start harder in the Winter than my 4020.
I also have a chance to buy a '71 4520 with Hiniker cab but with a 4430 engine in it for $8995 with 8400 hrs but I've read in postings where the 4520 is quite heavy and awkward and only has a 1000 rpm PTO but the 4430 eng is a big improvement over the 4230 since the 4430 is turbo charged and has the Bosch horizontal inj pump. It has had a new clutch put in it and the rear main engine seal fixed. It dynos at 126 hp and hyd checks out at 2000 psi at 8 gpm which is a little low but may only need filters changed and trans screen cleaned. I suppose I could use my 3020 PS on the brush cutter.
I have a thought to get a cab and more hp to apply Anhydrous Ammounia or maybe I should just continue to hire it done and add weight and or duals to the 4020 to pull the Fld Cult better but I need quite a bit more into the 4020 to get the clutch replaced and it only has 1 remote SCV. The 4020 has fair compression at 300-310 psi per cylinder and varies only 10 psi between cylinders. I know I don't have that many acres but since I'm working full time in town, sometimes it is handy to get done with field work in a short time. I'm needing to stay in the $8-$9000 range if possible.
I'm thinking I need something in the 100 - 125 hp range with 2 SCVs and a cab to put on Anhy. and pull the full 18 ft fld cult. I also have a IH 470 16 ft disc (with wings down or 12 ft with wing up) and 9 shank chisel plow.
It takes about 90 hp to pull a 9 knife Anhy applicator and 2 SCVs to operate it and that's the smallest the local CO-OP has. If I had 2 SCVs I could also convert my Fld Cult to hyd fold instead of manual fold or get a hyd fold one.
What tractor would best suit my needs?
Thanks in advance for the info....
JDknut
06-09-2006 14:11:34
 Re: Advice on 4020 4230 4520(4430 eng) in reply to Vern Sanders, 06-08-2006 17:22:16
I'd go with the 4020, at least you know the history of it and are working your way thru the bugs, whereas with an unknown used tractor, you have a whole new set of bugs to start on. You might luck out and get a fairly straight tractor, but then chances are it would be a money pit that you have to start over on whereas you are already some of the way thru your existing money pit. Hope this all makes sense. Good luck.
JMS/MN
06-09-2006 08:17:01
For $1000 yuu could add duals, fluid on the inside tires, and a used SCV to your 4020, which you know the history of. At worst, a few hundred more for a good used cab. Will pull that 18 foot FC across that 40 acres in 5 hours, and matches the other equipment you mentioned. 4520 is overkill for that size equipment, and not as fuel efficient.
Gunner
06-09-2006 06:30:26
Vern,
A 4230 is not a bad tractor and has by far the nicest cab of the tractors mentioned but with it being that cheap it makes me think it has problems. The 4520 will do a nice job with the tasks you are talking about. They are not as nimble as a 4020 but for tillage and Anhydrous application it will work nicely. My vote would be for the 4520, option 2 would be fix yours and I think I would pass on the 4230 unless you had a really good chance to check it out first. Maybe it does need work that you don't need to have done right away like A/C, cab kit and paint. You could buy it and do those as the budget allowed. If it is internal like engine, transmission or hydraulic pump I would stay away. I don't know what you have in your area but you might be able to find a 4320 in your price range. That would give you the power of a 4520 with the 540/1000 PTO and handling of your 4020. Good Luck
Gunner
