Glen in TX / 2020 Hydraulic problem
CLK n Cypress
06-08-2006 16:13:27
Have a 2020 diesel and when the 3 pnt. lever is all the way up or all the way down the hydraulics work fine. In any other position (after a minute or two) first the 3 point will start chattering then a moment later it starts to loosing the steering then the blade (which is connected to hyd. system behind seat). Can this system be diagnosed or isolated to determine which part of the system is failing? The local dealer thinks the charge pump is gone and a grey headed wrench sais the control lever needs to be set but he's in the Hill Country. What you think cause hay season is on!
CRUSADER
06-09-2006 02:36:32
 Re: Glen in TX / 2020 Hydraulic problem in reply to CLK n Cypress, 06-08-2006 16:13:27
Hey I'm not a JD 2020 expert and it's been many years since I worked on one. There's an adjustment on the quadrants (I think that what it was called) that is most likely off. Take a look at your rockshaft housing and there should be an inspection plate or you may have to remove the rockshaft. Your manual should describe how to do the task. Hope this helps and isn't too full of mistakes.
Jim
Glen in TX
06-08-2006 17:28:53
I'm not no 2020 mechanic but you should be able to do a pressure test before just thinking a pump is bad. It may not be getting oil from plugged screen or filters or a relief valve messed up or something out of adjustment or broke spring? You'll just have to do some detective work through it and see what you find and use a shop manual also. You can study the system in parts catalog at jdparts also.
CLK n Cypress
06-09-2006 04:59:44
 Re: 2020 Hydraulic problem/ 3 point chattering in reply to Glen in TX, 06-08-2006 17:28:53
Filters, oil & screens are new. The tractor hydraulics will work perfict any & all day long up until The 3 point lever is somewhere besides all the up or down, On this sysem the local JD place thinks it's the charge pump. A mechanic friend (out of town), sais it's a closed system and can be pinpointed to what/where the problem is. My thought is I don't think any of the punps are starting to go bad due to it ONLY happens if the 3 pnt. is used besides all the way uo/down. I can place the lever all the way (in either direction) & it will stop having a seisure and work great again. Wondered if you guys ever delt with a similar problem. Many Thanks for the help, past/present Clay.
Tx Jim
06-09-2006 08:26:21
 Rockshaft control valves????????? in reply to CLK n Cypress, 06-09-2006 04:59:44
As I stated before the rockshaft valves or L&D controls aren't adjusted correctly. NEEDS TO BE ADJUSTED PER JD TECH MANUAL Tx Jim
Glen in TX
06-09-2006 07:13:00
 Re: 2020 Hydraulic problem/ 3 point chattering in reply to CLK n Cypress, 06-09-2006 04:59:44
Sounds like Jim & Jim pointing you in the right direction on adjusting control valves. See if your dealer has copies of the SM2072 Service Manual which covers most 2020 models except for 2020, ser.no. 117500 and up which will need TM1044 Technical Manual. JD manuals 800-522-7448. Otherwise at least find a I&T manual.
Tx Jim
06-08-2006 16:40:58
I'm not Glen but I'm from Texas. I would check the clearance on Rockshaft control valves,adjust load and depth control according to JD tech manual. I would then look in hyd. filler hole to see if any oil is spraying from RS valves. HTH, Tx Jim
