JD 4010 power steering
Norman Al-Anbar
06-08-2006 14:39:45
I did not start my JD 4010 for 8 months. I put new battery and new filters and new Diesel it started very good no problems, however I could not get the power steering to turn to the right and I got too much smoke coming from the top of the engine in the tub going to the right side. The steering goes to the left and stop in the center. So I stooped the truck worried that I may cause damages to the pumps or something�any ideas? I let it run for about 5 min only�but the smoke was too much. Tube located next to the injectors�also any ideas where to get front tires around Temecula California? (Does turning the steering without running harm the system, as the kids were playing on it)?
HTR
06-09-2006 04:14:19
 Re: JD 4010 power steering in reply to Norman Al-Anbar, 06-08-2006 14:39:45
On the steering problem, with the engine running, turn the steering wheel all the way to the right, and hold it there, until the steering synchronizes. Right turn uses trapped oil in the steering motor and steering piston. If the kids have been playing with the steering, it would be normal for trapped oil to be lost. It will only take a minute for the wheels to catch up, and then steer normally.
Norman Al-Anbar
06-09-2006 13:37:26
 Re: JD 4010 power steering in reply to HTR, 06-09-2006 04:14:19
God bless for your speedy reply�KI did follow your instruction but still no luck. When you turn the steering wheel from right to left full turns you get 5 turns. My tires are facing the left side, when I turn the wheel to the right I get three full turns (nothing moving) before the tires start moving to the right but the last two turns the tires moves and stop at the center. I try to move the steering more to the right but it will not move any further. It is like the steering wheel moved three turns to the left ��
lonzo
06-08-2006 22:29:58
know it doesn't hurt the steering when it is being used with the engin dead, I would check the pressure at the steering supply that is located on top of the pressure regulator valve that is under the cowling, The reading needs to be 2250 PSI at 1900RPM. get a repair book first and then ask some JD repair guy for help. Good luck and hang in there you can do it.
Norman Al-Anbar
06-09-2006 13:43:40
 Re: JD 4010 power steering in reply to lonzo, 06-08-2006 22:29:58
Thank you for the reply...I did check the pres. and it is around 2100, as I stated in my reply to the other post, It is like the steering wheel skipped three turns to the left it is usually 5 full turns from right to left I have three turns before the tires movs and on the fifth turn it stop...God bless you and can you tell me where can I found the section for that problem in the repair manual?
Norman Al-Anbar
06-08-2006 19:31:57
 Re: JD 4010 power steering (Follow-up in reply to Norman Al-Anbar, 06-08-2006 14:39:45
Follow-up
I filled the radiator with lots of water as it was totally dry
No Steering at all to the right
The oil under the seat hydraulics changed to off color as it may mixed with milk;
The three point hitch does not work now and will not left-up- a load on the arms. The pump it may be busted, any solutions for repairs or cause?
God bless and thank you all for great help�.
Glen in TX
06-08-2006 22:19:50
 Re: JD 4010 power steering (Follow-up in reply to Norman Al-Anbar, 06-08-2006 19:31:57
"The oil under the seat hydraulics changed to off color as it may mixed with milk" ??
It's not mixed with milk. It has water in the oil giving it the milky off color and you need to drain and flush the whole system. It may take more than one time to get it cleaned out but get it drained and flushed and filled back with new oil and trans/hyd. filters changed and then see what other problems you may still have. If it gets cold enough in your area to freeze water solid in winter then it could have damaged or busted something else but water in there can also rust making valves stick and springs rust and break.
Norman Al-Anbar
06-09-2006 13:32:33
 Re: JD 4010 power steering (Follow-up in reply to Glen in TX, 06-08-2006 22:19:50
Thank you for your speedy reply and I will follow your instructions, but I do not know the best place to drain this oil? I called the local JD and said that I have to pay for them to get the tractor to service and they do not give advice to anyone�I just got the repair manual do you know what page? LOL I had hard time starting the tractor before I left and now the tractor start without any problems or delay from the first kick but now I got this two problems�
Glen in TX
06-10-2006 13:14:47
 Re: JD 4010 power steering (Follow-up in reply to Norman Al-Anbar, 06-09-2006 13:32:33
Should be a plug on bottom side of trans case and you may have to slide the drawbar over or remove it to get to the drain plug. Sit down and read that manual some evening.
Norman Al-Anbar
06-10-2006 16:52:32
 Re: JD 4010 power steering (Follow-up in reply to Glen in TX, 06-10-2006 13:14:47
Update
I drained al the hydraulic oil and washed the system by using 5 clean gallons of oil put in the system until clean oil came out from all sides�As soon as I opened the drain plug I got about � gallons of pure water and then oil mixed with water�I do not know how all this water came in the system.
Anyhow the three point hitch did not come up until I start playing with the steering wheel and it is now working somewhat. The steering wheel still does not turn to the right it end up full to the right but the tires are straight. All three problems are connected somehow and I hope someone know how to fix it
I thank you for the information that did fix the first problem and I am waiting to see if you can give me another one for that steering.
God bless you all
P.S. I had the time to go through the manual last night and this morning I did the work thank you for your help
