2 sets of hydraulics on single spool
Hilltopper
06-08-2006 13:35:58
Does anyone know if the diverter that is used to double the number of hydraulic spools on a tractor will work on a 6 volt system? Since they are a later invention I assumed they were 12 volt. Thanks
Glen in TX
06-08-2006 18:10:50
 Re: 2 sets of hydraulics on single spool in reply to Hilltopper, 06-08-2006 13:35:58
All I've ever seen or used were the 12V ones. Check with some of the farm supply places or dealers. There are some manual type diverter valves you can plumb in also and some joy stick type valves you could use but need to be sure to match joy stick valves or extra spool valves to whether you have open or closed hyd. system. Here is a link for some hyd. valves also:
Hilltopper
06-09-2006 13:07:03
 Re: 2 sets of hydraulics on single spool in reply to Glen in TX, 06-08-2006 18:10:50
I am using a push pull knob type diverter valve to operate a 510 Jd baler. When it ties the bale and cuts the twine and I divert the oil to open the gate it releases the pressure on the twine tie cylinder and allows it to release the twine and it gets into the pickup as I am rolling the bale.It seems to back feed through the return line on my 720 D. It seems to need a diverter on the return also.Any thoughts on this. Thanks.
