JD 3020 Questions
Illinois Farmal
06-07-2006 14:51:31
I"m not very familiar with the green tractors but I"ve found a NF gas 3020 that has aroused my interest. It is very clean condition i.e new paint all around and new tires. I haven"t heard it run yet as I was just passing by the dealer and stopped in for a moment. He"s asking $5500 for it and said he would give me $1800 trade for my 53 Super M in the condition I described it. How are these tractors overall? Any problems that plagued them? I assume they have live pto and a high/low range. I want it primarily to run my NH 268 baler. Would this tractor be a good match up for it? Thanks in advance.
Glen in TX
06-08-2006 08:04:35
 Re: JD 3020 Questions in reply to Illinois Farmall, 06-07-2006 14:51:31
Sounds like a good buy if it's like you were told and in good condition. They had interchangeable stub shafts for 540 or 1000 rpm PTO. Go drive it and try out the hydraulics and run it through all the gears. A little info on 3020 at the forty-twenty.com site.
Illinois Farmall
06-08-2006 15:02:37
 Re: JD 3020 Questions in reply to Glen in TX, 06-08-2006 08:04:35
Went and looked at the tractor again this morning and talked with the dealer. Looked at it top to bottom and didn't see a thing wrong with it other than the top link for the 3 point was missing and I forgot to ask about it. It fired right up and sounded and ran good...altho I have to admit I was a bit confused with the shifter pattern LOL Being around Farmalls all of my life I wasn't at all familiar with it. The new paint job on it was done very well....even in the hard to get at areas and I didn't see any obvious signs of damage in the common areas. A big plus for me was the fact it has new tires all the way around...only wish it was a wide front but I guess we can't have everything. The dealer came out this afternoon to look at my Super M and said he's allow $1800 trade as he said yesterday so I'm happy with that. Now all I have to do is convince the bank (the wife) LOL. Thanks for posting the link.
Glen in TX
06-08-2006 18:02:45
 Re: JD 3020 Questions in reply to Illinois Farmall, 06-08-2006 15:02:37
It sounds good so far. They may have the top link hid inside as those tend to walk off like PTO shafts. Sounds like it must have syncro range trans and those are tough to beat. It has sycronizers letting you just slow and clutch and shift in that range but not having to come to a complete stop unless going in reverse. 1-3, 2-5, 4-7, & 6-8. If ever planning on a round baler later on you want to make sure the ranges all shift well, especially 1-3 and 2-5. Just hadn't occured to me till rereading you said it had the narrow front end. We always preferred the wide front end too for stradding the windrow when baling with our old 2510 and super 178 NH baler. Really need the wide front if wanting to hook to a big round baler later on. The good thing is the front ends are interchangeable and can always put a wide front end on it later. Ed Beem parts sells some HD front ends for loader tractors and has parts for others too. You might find another good front end at a salvage yard later too. Good luck with the bank (wife).
JMS/MN
06-07-2006 17:16:37
3020 is a nice baler tractor. Has independent pto, and the transmission would be either a Synchro Range or Power Shift. 8 speeds forward, 2-4 in reverse depending on which transmission. SR might have 3 reverse- I know little about them and like them less. PS is a great system. Whichever tranny- drive it first and see how you like it. HP is 63-70, depending on age.
