Flat tops on a 60
Kevin
06-07-2006 14:03:10
I pull a JD 60 is 7500,8500,9500,10500, and unlimited classes. It only weights 6400lbs with 18.4 38 tires on it. I am looking to put as many nice functional accesories on it as posible to help weigh it down some as them weights get heavy when loading a 6400lbs tractor to 10500lbs and i always loved a big fender. Is it posible to put a big set of flat top fenders on it from a 630? Or is it really hard to do? Let me know what has to be done or if anyone else had done it. Also will a wide front gain much more weight than a rollomatic or wont it be that much more? Im not quit sure what a rolomatic weights so please excuse my ignorance.
DTHJr.
06-10-2006 19:05:02
 Re: Flat tops on a 60 in reply to Kevin, 06-07-2006 14:03:10
Do you get the Hook Magazine? In the classifieds there is a JD60 pullin' tractor the guy is asking $20,000.00 for it! It has a nice, slick pair of fenders on her!
johns48b
06-07-2006 19:43:52
i'm not sure how much weight that would gain for you, but i would think it would be a whole lot safer with fenders on it.
B-maniac
06-07-2006 18:44:38
Somewhere between Sept. 05 and Nov. 05 Green Magazine on the back page was a shot of a 70 with those fenders.Best lookin' 70 I've ever seen.Does have a wide front though ,which I think balances out the big fenders for a nice look. Don't know if it would look as good if it were a narrow front.Just my opinion though,you do what you like.
mjbrown
06-07-2006 15:16:22
If there are holes on the top of the axle for a fender bracket that matches the ones on a 630 you can buy new reproduction brackets for the flattops. Those brackets are different than the brackets after 1960. The flat tops from the new gen tractors will fit the older style brackets though they will have a handhold on both sides where the two cylinder era ones have a hand hold only on the left fender. I've seen flat tops on 720's and they look nice and I'm sure some owners of older tractors ordered flat tops for them when they came out in 1958 with the 30 series.
