John 420 Transmission/Hydraulic Fluid
Arkansas Bill
06-07-2006 13:55:04
Is it a correct assumption that you use 90 weight oil in the transmission and hydraulic fluid in the power lift system? I assume that they are two separate systems and that the hydraulic system does not use the tranny fluid.
alan from texas
06-08-2006 18:18:17
 Re: John 420 Transmission/Hydraulic Fluid in reply to Arkansas Bill, 06-07-2006 13:55:04
I JUST DRAINED MY CRANK CASE BILL AND THERE ARE 3 SEPERATE SECTIONS .1 APEARS TO BE UNDER THE SHIFTER THE FILL HOLE IS TOP RIGHT THE DRAIN IS ON THE BOTTON LEFT.THERE ARE TWO DRAINS AT THE BACK OF YOUR TRACTOR ..,RIGHT AT BACK BOTTOM ,ON BOTH SIDES ,4INCHS ABOVE THEM IS YOUR FILL LEVEL PLUGS. THEY TAKE 3/8 SQUARE EXTENTION AND WHEN YOU DRAIN 1 AT A TIME YOU CAN TELL THEY ARE SEPERATE. I AM THE PROUD OWNER OF A 420...
FDBYRD
06-08-2006 05:53:21
BILL ,THE TRANS. NEEDS 90WT. THE HYD. SYS CALLS FOR 10WT , BUT I HAVE BEEN RUNNING 30WT IN BOTH OF MINE FOR YEARS WITH NO PROBLEMS. WHERE IN ARK ARE YOU? I AM IN MALVERN.
Ray
06-07-2006 16:05:07
The tranny fill is on the right side of the tranny just behind where your foot would be if you were setting on the tractor.The hydraulic fill is under the seat,also used as a breather.I've seen anthing from 90w to 140w used in those tranny's mostly to quiet the noise.Hydraulic oil will work in the rockshaft unit,some books recommended 10w,but that was back 50 years ago when they were built.
Ray
06-07-2006 16:08:26
 Re: John 420 Transmission/Hydraulic Fluid in reply to Ray, 06-07-2006 16:05:07
Forgot,there's a brass valve on the rear of the rockshaft assembly (looks like a radiator drain) that you use to check the oil level,just open it,add oil,when it runs out it's full.
Arkansas Bill
06-08-2006 05:16:05
 Re: John 420 Transmission/Hydraulic Fluid in reply to Ray, 06-07-2006 16:08:26
Ray,
Thanks for the info. I have the shop manual but don't have an owners manual.
