4020 powershift no park
toby
06-07-2006 04:17:49
We have been cutting hay and now the park does not work. How much trouble to fix? What has to come off inorder to get to it?
Thanks Toby
Chris Kendall
06-19-2006 20:17:41
 Re: 4020 powershift no park in reply to toby, 06-07-2006 04:17:49
Get some PB penetrating oil(Power Blast) spray cable behind rh battery, take vise grips and clamp on to cable and hit the vise grips with a hammer to work cable back and forth while spraying it with PB. If entire cable move then it needs to be reclamped or the clamp needs to be tightened. Or just haul around a 4x4 block with you.
lonzo
06-08-2006 22:44:16
remove the right battery box and the cable is on the side of trans case at the top. Most of the time the cable comes unhooked or the clamp that holds the cable housing is loose or broken. If the cable is stiff i have drilled a small hole in the tube above the out side cable and used diesel, brake cleaner to free up the cable.
Maark
06-07-2006 07:16:12
Probably just the shift cable. They become dry and bind up with age. Never seems to work to apply penetrating oil down the cable.
JMS/MN
06-07-2006 17:22:33
 Re: 4020 powershift no park in reply to Maark, 06-07-2006 07:16:12
I was able to free up the one on my 3020 by chucking it in a drill, lubing, pulling it back and forth with the drill. Messy, but it worked that time.
