JD Gator Info Needed
Nathan(GA)
11-30-1999 20:24:49
First, what's your opinion of them good or bad? Do the transmissions hold up? Seems like an awful lot of scrubbing gears when going from neutral to forward or reverse. Thanks for your comments.
Nathan
JDGnut
12-02-1999 22:55:13
 Re: JD Gator Info Needed in reply to Nathan(GA), 11-30-1999 20:24:49
I also have not seen any problems with the tranies in the gator. We have a diesel. The only complaints are with the 2 cylinder gas engine, then tend to foul plug on a regular bases. If you are looking for a big gator, I'd go with the diesel. Its more dependable and fuel effiecent. The small gator is only avialable with the one cylinder engine (air cooled) and seems to be holding up very well. I only have two complaints about them, One the grinding of the trany. (But I have yet to see one fail.) Two, it needs a road gear. A two speed trany or something. Well good luck.
JDGnut
Nathan(GA)
12-03-1999 10:36:38
 Re: Re: JD Gator Info Needed in reply to JDGnut, 12-02-1999 22:55:13
Thanks JDGnut, I have the same complaints. I don't own one yet. I guess the gears are made of some good stuff. I haven't heard of anyone having tranny problems.
Nathan
Brian Nielsen
12-01-1999 19:11:20
I work for a rental company and we rent out gators alot. All of them get used and abused but so far no problems with the traney. Brian
Conrad Desai
05-02-2000 06:49:19
 Re: Re: JD Gator Info Needed in reply to Brian Nielsen, 12-01-1999 19:11:20
HI there !!
I,m Based in Kuwait and need 3 nos Gator made by John Deere, the Gators should be 6x4 and with all options such as Top Canopy and shield, 4x4 screen option etc.
Your response ASAP will be appreciated.
Conrad
Bruce
06-30-2000 09:45:11
 Re: Re: Re: JD Gator Info Needed in reply to Conrad Desai, 05-02-2000 06:49:19
Hi I was just wondering how much a used 1998 4x2 gator would cost?
Joe
08-17-2000 08:50:08
 Re: Re: Re: Re: JD Gator Info Needed in reply to Bruce, 06-30-2000 09:45:11
Check out MachineFinder.com! With enough patience, you can find a lightly used 4x2 Gator for $3500 to $4000. You do, however, have to sign up to use their search engine.
Joe
08-17-2000 08:49:35
Check out MachineFinder! With enough patience, you can find a lightly used 4x2 Gator for $3500 to $4000. You do, however, have to sign up to use their search engine.
Nathan(GA)
12-02-1999 20:16:36
Thanks Brian.
