rpm
johndeereman
06-06-2006 16:57:30
anybody know how to get more rpms out of a 43 jd b without spending lots of money rules of the pull say no chains or strings on governer gov. has to be functioning is there any other way to get cheap rpms thanks johndeereman
Dane in PA
06-08-2006 18:14:40
 Re: rpm in reply to johndeereman, 06-06-2006 16:57:30
I dont know much about the earlier JDs, as both of mine were '51 models, but: on my 'A', there is a bolt on the bottom part of the throttle lever (by gear box) that sticks out to stop the throttle arm. By taking this bolt out, the throttle can be pushed all the way to its maximum. I sent the rpm's on that 'A' from about 1000 to 1250. Like i said though, I dont know what the earlier models were like. hope this helps
buickanddeere
06-07-2006 15:24:16
The torque curve is dropping fast when the engine reaches full HP at 975. That why the two cylinders feel so strong with the torque rise in the 700-800 rpm range. At 1379 rpm the internal stresses will be twice as high as when at 975 rpm.
van robinson
06-06-2006 23:08:19
I agree with Drew. You need to be careful with trying to get higher RPM's out of that old girl. I mean, it is 63 years old. I have a 1940 B by the way. Also, remember, that is a long stroking engine with a lot of weight in motion. When you start running the RPMs up, you have a lot of momentum in the flywheel, those big pistons and connecting rods and crankshaft and such. If you get that much weight moving in one direction at a high rate of speed and then try to make it change directions, such as the back and forth motion of the pistons, you may wind up breaking something. Seen it done before.
You don't need higher RPMs to pull. If the gov works as it should, it will open the throttle up when it needs it.
Just my 2 cents.~
Drew
06-06-2006 18:59:55
You can put a 2nd stock spring on the gov, or put a steel strap along the spring and fasten it to the spring w/ the bolt that attaches the spring(s) to the govornor arm.
Dont get stupid with high RPM, as you are dealing with 50 Y.O. cast iron. With a stock engine, as soon as you put a load on the engine, you are going to fall to stock RPM or below, so you arent really going to gain a thing.
