4010 ?
MN Bob
06-06-2006 07:03:45
I bought this 4010 Diesel three years ago and have had no problems, but I notice it smokes a little now, not just at startup. When I start it I pull the throttle back about 1/4 and it was always ok. Lately it sometimes, runs up like it was wide open, a quick movement of the throttle and its ok. Only other thing is it has never held its RPM well. I have to hold the throttle to maintain RPM's at any speed or gear. Cable or adjust? I have the operators manual but nothing there. Thanks for any help. Bob
johns48b
06-06-2006 15:55:59
 Re: 4010 ? in reply to MN Bob, 06-06-2006 07:03:45
this is weird! todays copy of green magazine on page 56 deals with this problem in service bullentins notes section. it says to tighten the clamp at the base of the throttle lever tube. it will probably have to be adjusted once or twice until the facing becomes worn to a uniform service. end quote. there is an illustration in there too. lol
Bob
06-06-2006 19:35:37
 Re: 4010 ? in reply to johns48b, 06-06-2006 15:55:59
90% of the time, you have to weld up the tensioning clamp at the base of the throttle tube BEFORE you can tighten ut uo!
MN Bob
06-06-2006 13:36:11
Thanks guys, Always good help here. I will get on that throttle and hope to get more on the smoke. Bob
Glen in TX
06-06-2006 13:05:23
Woodbutcher has you lined out on it. If the pad is completely gone and you have to pull the column tube you can view the 4010 parts book at jdparts online and see what else you might need. If pad is worn and gone other parts are likely worn too like bushing, seal, & throttle shaft stop rod parts.
woodbutcher
06-06-2006 07:23:29
Bob,
I had a similar problem with the throttle on my 3010 concerning holding the rpms steady. I found the cure when I replaced the power steering unit. The steering column sits inside a sleeve onto which the throttle lever is mounted. The bottom of the sleeve is split so that it can be tightened down against the column with a bolt that is mounted on the sleeve. There is a fabric pad in between the column and sleeve which looks like asbestos. I picked up a new one somewhere. That was all that was necessary to keep the throttle where it is set. HTH
Butch
David from Kansas
06-06-2006 07:16:08
When you say you have to hold the throttle to maintain RPM's, do you mean the throttle moves back toward idle if you let go of it? If so, you need to tighten the tension on the throttle lever, which I believe is shown in the operator's manual. Otherwise, it sounds like a pump problem, probably a rebuild. I'm sure G-man(?) or Glen in TX can shed some light on your problem, as they are JD mechs.
