4020 injector pump
toby
06-06-2006 04:44:49
My 67 4020 is running at higher rpms at idle. Runs fine at pto speed but real eratic when you pull the throttle back. Do I have a pump problem and how bad is it
Toby
jdemaris
06-06-2006 05:52:19
 Re: 4020 injector pump in reply to toby, 06-06-2006 04:44:49
First you need to make sure there is not air in your fuel. If there are air bubbles (look in your filter bowl), very often the engine won't idle properly. Air can be caused by a bad fuel pump, clogged line or screen inside the fuel tank, etc.
In regard to the injection pump - you need to ascertain which model pump you have - 4020s used the small roundish C model pump and also the larger and longer DB and JDB pumps. The C pumps do not have any governor "band", but do have a set of rack and pinion gears that operate the throttle and tend to wear out teeth over time. They can be easily replaced without removing the pump. The C pump has a long stem sticking out of it where the throttle linkage hooks - that stem has the rack and pinion gears in it.
If you have the longer rectangular pump - some have a governor ring and some do not. Many pump shops eliminate it. I always get rid of it with any DB or JDB Roosamaster pumps. If your 4020 has this pump, and the plastic ring has shattered, usually it breaks into tiny pieces, and they tend to get stuck in the fuel outlet of the pump (that hooks to the return line that goes to the injector boots or Ts). When this fuel outlet begins to get plugged, the engine will not hold a steady RPM. When it gets totally plugged, the internal housing pressure gets high and the pump shuts down - seeming like its out of fuel. In some pumps this fitting has a spring and check-ball in it and serves as a housing pressure regulator.
As the other guy said - eventually - the steel rivets will break and the governor won't work at all. Sometimes that can take years. In my own experience (we had our own Roossmaster/Stanadyne pump shop at our Deere dealership) I never encountered a tractor that lost all governor control (at least not a four-stroke cycle). We did have a few Deeres with Detroit Deisels that did it. But . . . with the Roosamaster DB or JDB pumps, usually the pump craps out before the rivets are completly gone. Under normal circumstances, the outlet gets plugged - the engine won't run - and the pump gets fixed. If, someone reams out the port, line, and/or fitting, and keeps it running - the metal from the rivet wear will usually ruin the head & rotor of the pump and it will stop running. Probably somewhere out there one has lasted long enough to lose all governor control - but I haven't come across it.
4020s had the following pumps usually in this order (but I've seen exceptions):
CBC633-1AL, CBC633-18AL, CBC633-24AL, CBC633-28AL, DBGVC633-1AJ,
DBGVC633-3AJ, DBGVC633-5AJ, JDB633AL2402, JDB633AL2404, JDB633AL2719,
and JDB633AL2721.
JDBert
06-06-2006 05:22:42
The govenor band is going bad. If it lets go it shears off 3 little pins- it'll then get full fuel and you cant shut it down and BOOM!!! motor parts all over the place. It'll probably run for awhile BUT the symptoms you have now will continue to keep getting worse.
