JD 4450 PTO Disengages
N. TX Tim
06-05-2006 22:07:31
Was round baling with my 4450 tonight and after baling a few bales, the PTO lever released. It did this for a couple bales, then it worked fine for a couple and so on. When it stayed engaged for an entire bale, it definitely seemed soundly latched when I disengaged it. Hydraulics and everything seemed fine. Seems like it is a worn latch, weak spring, dirt/grime under the dash or something minor. Where should I start...pull the dash cowling????
Thanks, Tim
G/MAN
06-06-2006 07:30:05
 Re: JD 4450 PTO Disengages in reply to N. TX Tim, 06-05-2006 22:07:31
That's not a rare problem, and many different things can cause it. Most common is dirt and debris building up around the valve actuating arm down at the PTO valve behind and to the rear of the LH battery box. Corn stalks, etc. Have someone operate the lever while you watch the linkage and then reach back where you see the linkage lead and make sure there's not a bunch of garbage built up back there.
Tx Jim
06-06-2006 03:11:24
Tim,if you look under Sound-gard body on left side there's a valve that has a piston in it that when pto is engaged pisiton pushes on arm to lock pto in gear. Likely the arm that piston pushes on is bent. You have to remove valve body to see arm. I relaced arm on my 4255 several yrs ago. Also badly worn SG body mounts can cause problem also. Tx Jim
