2020 gas hydraulic fluid leaking into oil?
Gary Freeman
06-04-2006 23:58:15
Is it possable to get hydraulic fluid into the oil? My oil dip stick gains about two inces in one hour running time. All the loco tractors dudes said it had to be gas, never has smelled like gas and still has slick feal to it. I changed the float in carburator, still the same, installed new fuel pump, still the same. I put a new water pump on a few weeks back, is there anyway I got a line wrong when I put raidator back in? I am losing hyraulic fluid real fast, not any leaks thew...Why never any thing normal. Gary
Tx Jim
06-05-2006 03:50:03
 Re: 2020 gas hydraulic fluid leaking into oil? in reply to Gary Freeman, 06-04-2006 23:58:15
Gary,the early 2020 diesels had a power steering pump mounted on front of engine but I'm not sure about gasoline engines. Look on RH front timing cover for pump,if it's there seal is leaking. Tx Jim
