430 Carburetor rebuild
Terry E
06-04-2006 19:07:06
I recently purchased and installed a rebuild kit on my 430 Carb. It was interesting that some of the parts were significantly different from the originals, but I think it went together okay. I removed every possible part and cleaned all of the passages well.
Now I am getting the "idle surge" mentioned by others in this forum. As I did clean all of the passages and the float was set correctly, I see 2 possibilities:
1. The replacement parts are not right for the carb.
2. I put something together wrong.
Any suggestions?
Thanks,
Terry
johns48b
06-05-2006 08:26:03
 Re: 430 Carburetor rebuild in reply to Terry E, 06-04-2006 19:07:06
there is a good section on carbs listed under jdhpubs.com. its for jd h tractors but is still worth the time to read if you want to learn alot about carbs. on small engines that hunt, i've found that its sucking air around a shaft that causes that problem.
Terry E
06-06-2006 17:32:52
 Re: 430 Carburetor rebuild in reply to johns48b, 06-05-2006 08:26:03
Thanks a lot. That is a really good article on carbs. I never have understood how they work.
Will try some of the tips and see if they help.
Duane Larson
06-04-2006 20:04:15
Terry,
Your 430 came with a Marvel Schebler TSX688, assuming it has a gasoline engine. It has both an idle jet and an economizer jet, both located in the top of the carb, viewed from the underside. If you removed those and cleaned the passages, then you might check the adjustment of the throttle-stop screw as if that is not screwed in far enough you can get the hunting problem.
What replacement kit did you get, and what parts were different?
Terry E
06-06-2006 17:28:54
 Re: 430 Carburetor rebuild in reply to Duane Larson, 06-04-2006 20:04:15
Thanks.
I got a rebuild kit from JD Heritage. One of the jets was completely different, as well as the float attachment mechanism.
