Carb ID
MoeGibo
06-04-2006 19:05:41
I am trying to get an ID on my carb for my 1950 so i can get a rebuild kit for it. The only writing i see is DLTX and IDLE ADJ AND LOAD ADJ. Can anyone help with where i might find a number on this thing?
Duane Larson
06-04-2006 19:55:11
 Re: Carb ID in reply to MoeGibo, 06-04-2006 19:05:41
MoeGibo,
Right after the letters DLTX there is a flat spot and there should be some numbers stamped in there. If you have a gas B it should be 67, gas A would be 71, G would be 51 ... . Or, if it is a late replacement carb there would be a round aluminum disc in the top center of the carb with a number stamped on it.
amo
06-05-2006 06:09:17
 Re: Carb ID in reply to Duane Larson, 06-04-2006 19:55:11
roberts carburator has a good list of all carbs for john deere. robertscarbrepair.com good luck.
