1360 mower conditioner with flails
Kyleenright
06-04-2006 09:57:28
Does anyone have any comments on a John Deere 1360 mower condtioner with flails and a swivel hitch (3point hitch) I am looking at a used one right now and would like to know the good and the bad about these mowers.
Thanks!!
tractorfixer
06-04-2006 20:32:47
 Re: 1360 mower conditioner with flails in reply to Kyleenright, 06-04-2006 09:57:28
The 1360 mo/co is good machine. The flails will help get hay dry sooner. The cutterbar is not manufactored by Deere, but is outsourced (Kuhn I think). The cutterbar is one complete unit and is VERY sensative to oil level. It is nearly impossible to know how a used machine has been cared for in the past. However, the only correct way to check the oil level on these cutterbars is to tilt one side up, and drain the oil out of the other side(let drain for at least 24 hrs), measure the oil (or better yet, change it), and then refill with the correct amount. An overfilled cutterbar builds up heat and melts the plastic retainers in the bearings and the mo/co will shake and bake. An underfilled cutterbar can cause bearing or gear failure. I hope this is a help for you as you shop for a mo/co.
johns48b
06-04-2006 16:05:10
i don't remember the number of the one i use to run. it pivioted in the middle of the machine and was a honey to run. i was in a field yesterday where three jd tractors were cutting hay with the whirling disk type mowers. two were kuhn and one was a jd. the jd was so quite you couldn't hear it run at all. the others were noisy as they could be. they cut 22 acres in 1 hour. i've run a lot of ih m/c with the old sickle type blades in them. they nearly broke me trying to keep them up. if i were buying today i'd get the whiling blade type with a frail conditioner. hay cut with a conditioner will nearly always bale the next day. it will pay for it's self in saved hay. check to see if the blade sits flat on the ground on a level surface. that will tell you if the frame is wrapped up or not. check the drive mechanism out to see if its be broken off.
moegibo
06-04-2006 14:07:41
These are a pretty decent mower. I have a 1350 myself and the only problem we had was the skid plates broke off a few times. John Deere has an upgraded kit for rocky fields and we have had no problems since that install. Hope that helps you
