G/Man Power curve for 6619
5020Chris
06-04-2006 09:52:12
Hey G/Man, a couple of months ago I posted a question about how much hp is safe to dyno. In your reply you asked for a engine number so you could find a power curve for the 6619 in my tractor. I have taken the down these numbers from the side of the block on the plate towards the rear of the injector pump and they are repeated again on the plate on the rocker cover. They are as follows RG6619A060205 6619AF-00 (L) Base unit 1245F
I hope these are of help and that you can turn somthing up. The lead seal is still on the injector pump and it dynos at 305hp and nothing has been touched as far as I can see.
Regards
Chris.
JDGnut
06-04-2006 21:13:18
 Re: G/Man Power curve for 6619 in reply to 5020Chris, 06-04-2006 09:52:12
Product Serial Number: RG6619A060205 Base Code: 1245F Rating: N/A* Model No: 6619A EPA Family: N/A* Manufactured Date: N/A EUR Family: N/A* Emission Part No: N/A EPA Certificate: N/A* Parts Catalog No: N/A Carb Certificate: N/A* Option Name Ordered Production Distributor ROCKER ARM COVER * 1104 1104* OIL FILLER COVER * 1201 1201* CRANKSHAFT PULLEY & DAMPENER * 1304 1304* FLYWHEEL HOUSING * 1401 1401* FLYWHEEL * 1505 1505* FUEL INJECTION PUMP/SYSTEM * 1601 1601* AIR INLET/INTAKE * 1707 1707* OIL PAN * 1901 1901* WATER PUMP * 2001 2001* THERMOSTAT COVER * 2101 2101* THERMOSTAT * 2204 2204* FAN BELT * 2403 2403* COOLANT HEATER/BLOCK HEATER * 2699 2699* EXHAUST MANIFOLD * 2803 2803* STARTING MOTOR * 3005 3005* ALTERNATOR * 3199 3199* FUEL FILTER AND LINES * 3506 3506* THERMOSTAT HOUSING/EXPANSION TANK (MARINE) * 3903 3903* OIL DIPSTICK * 4001 4001* BELT-DRIVEN FRONT AUXILIARY DRIVE * 4199 4199* SHIPPING STAND * 5505 5505* PAINT * 5601 5601* ALTERNATOR MOUNTING * 6204 6204* EXHAUST ELBOW * 6401 6401* TURBOCHARGER * 6503 6503* SERIAL NUMBER PLATE * 6901 6901* COOLANT CONDITIONER * 7001 7001* OPERATING SENSOR * 7201 7201*
This is a list of Option codes for your engine.. it was once somewhere on the engine.. probably on the valve cover.. (until it was washed a few times..) These don't seem like important numbers, until you have to purchase parts for your engine... but the injection pump code can be used to see what the rated HP for this engine... Looks like it was a Marine engine.. at one time.. I'll try to get the other information sometime this week.. (HP rating) The reason there is two listings of numbers.. one is how the engine left the factory.. the second is if it was changed by an engine Dist... If I come across anything else.. I'll post it... (also posted them so I didn't have to look them up again.. haha..)\
JDGnut
