JD 2010 power loss
DLilly
06-04-2006 09:50:06
I have a JD 2010 with the 46HP engine. It seems to run OK during idle, but looses major power as soon as I put a load on it. Even when going uphill(even a gentle slop). I just recently changed the water pump. Any ideas? Thanks
Ted Dixon
06-04-2006 13:42:08
 Re: JD 2010 power loss in reply to DLilly, 06-04-2006 09:50:06
You didn't mention if the tractor or crawler was a gas burner or diesel. If it's a gas burner it could be the load jet on the carb not set right or a plugged air filter or not getting enough fuel (trash in lines or tank maybe). If it's a diesel it could be the timing of the pump or clogged filters or an injector pump that's about to go bad. I have read that the governor weight retainer slings apart on the roosa-master pump. These are just a FEW things that can cause this problem not to mention a lazy ignition system.
Dan Lilly
06-04-2006 16:39:22
 Re: JD 2010 power loss in reply to Ted Dixon, 06-04-2006 13:42:08
It is a gas utility tractor. I cleaned the air filter and it is running great. Thank-You.
