1935 B DLTX 10 Carburator needed
Jak
06-04-2006 07:49:29
After all the checking resetting and cleaning/inspecting I have come to the conclusion the carburator is not the right one for this tractor.It was exchanged a while back with lots of boot paid and according to the owner it never did run and start right.I thought it was awful strange that where the number was supposedto be stamped it looks like someone took a punch and distorted that area to where it looks like the bumpy casting.Why would someone do this other than to fool someone into buying the wrong carb for the tractor?????The gentleman whom I am working on his tractor needs a DLTX 10(good one not junk,we already have that).Are they still out there?Thanks,Jack(TN).
johns48b
06-04-2006 16:10:07
 Re: 1935 B DLTX 10 Carburator needed in reply to Jak, 06-04-2006 07:49:29
you might give marlyn smith at 712-489-2570 a call and see if he has a carb. you might want to read JDHPubs. he has a good section on carbs. marlyn is a nice guy to deal with.
Duane Larson
06-04-2006 08:35:06
Jack,
Check the diameter of the throttle disk (or the bore). If it is 1 5/16" it is a DLTX10 - that size is unique to the 10.
Where in TN are you located?
Jak
06-05-2006 10:25:37
 Re: 1935 B DLTX 10 Carburator needed in reply to Duane Larson, 06-04-2006 08:35:06
I was just looking at an inch and 5/16ths on the ruler and from my memory the throat/choke/throttle plate was a lot bigger than an inch and 5/16ths.I guess a B will run with a bigger carb but not well???What would one act like with a carb that was too big on it?Sorry for rambling on but this one has been on my mind a lot here lately gents.Jack(TN).
Jak
06-05-2006 06:28:08
Northwest corner near Martin.
Jak
06-05-2006 09:23:03
 Re: 1935 B DLTX 10 Carburator needed in reply to Jak, 06-05-2006 06:28:08
Hey Duane the owner already took it back home.The stem going down into the bowl has been broke off so I don't trust it anyway.If I still had it I could measure it.Nothing I could do would make it pull the gas in enough to start it quickly and no matter what I did I couldn't fine tune it to idle right or pull right.It was pefectly clean all throughout the idle passages and load nozzel.I have had several G's,A's,and B's that I was able to make them run perfectly but this one stumped me.Like I said it was funny the stamped number area was beat all to crap with no other marks anywhere else on the carb???Thanks Duane.
Duane Larson
06-05-2006 07:21:44
Jack,
Ok. I have some good 10's I can rebuild if you don't have a 10. If you provide the throttle plate dia, choke plate dia, and a pix we can likely figure out what carb is on it.
Jak
06-05-2006 10:20:40
 Re: 1935 B DLTX 10 Carburator needed in reply to Duane Larson, 06-05-2006 07:21:44
Where you located Duane?If I get the carb/tractor back I will definatly measure them cause I am definatly interested to see what carb is on it.The idle doesen't want to adjust down to a cluck cluck and when throttling up it stumbles and black smokes.I can adjust out the stumble and black smoking some but then it sputters like it is out of gas.The guy who owns it wants the right carb for it.I will tell him you might be able to fix us up.Do you want my email or do you want me to call you or email you?I put my email in the box.Thanks Duane,Jack(TN).
Duane Larson
06-05-2006 11:40:46
 Re: 1935 B DLTX 10 Carburator needed in reply to Jak, 06-05-2006 10:20:40
Jack - I sent you an email thru ytmag.
Jak
06-05-2006 12:48:59
 Re: 1935 B DLTX 10 Carburator needed in reply to Duane Larson, 06-05-2006 11:40:46
As of 2:40 central I haven't gotten one yet but maybe it takes a while to go through.Thanks
Duane Larson
06-05-2006 20:59:48
 Re: 1935 B DLTX 10 Carburator needed in reply to Jak, 06-05-2006 12:48:59
Jack,
If you didn't get my email, send one to me at [email protected]
