JD 300 16hp Kohler Problems
Sitka
06-03-2006 22:20:08
I recently purchased a JD 300 garden tractor, and it has running issues. The engine is the original 16hp Kohler. The engine stutters and hesitates as the throttle is increased or when the tractor is subjected to a load. If the throttle is raised extremely slow, it will eventually go to full RPM's. However if it is done to quickly (or if the load is not reduced) the tractor will quicly start to stutter and never really recover from it. Here is what I have done with no success: replace and set the points, replace and gap the plug, adjust the carburator for optimum performance (seemed to help a little). Any help would be appreciated as the engine seems to be powerfull with no strange noises or excess smoke.
Roger in Iowa
06-04-2006 18:57:26
 Re: JD 300 16hp Kohler Problems in reply to Sitka, 06-03-2006 22:20:08
Sounds like your idle and main jet adjustments are on the lean side. Open the idle about 1/8 to 1/4 turn (do not want black smoke) and main jet about an 1/8 turn also.
Roger in Iowa
Sitka
06-04-2006 08:07:11
Sorry, I did not disclose everything I have done. I did remove the carburator and clean it, and I replaced the air cleaner. The carb appears to be fairly simple, and I dissasembled it as much as I could. What is the best way to disolve the "varnish deposits"?
johns48b
06-04-2006 05:32:02
i'd take the carb off and clean it good. sounds like some of the passages in it are stopped up. be sure that the air filter is clean while your at it. i always put fuel stabilizer in my small engine stuff each fall and try to crank them all 3 or 4 times during the winter. sounds like somebody didn't do this and the gas has turned to varnish and stopped something up.
