JD 435 with oil pressure problem
cdm
06-03-2006 17:52:30
John Deere 435 diesel starts with good oil pressure, but drops to almost zero after about 15 minutes of mowing. First I added a manual gauge at the tee under the oil filter canister. Waited a day, ran tractor again. Both gauges dropped to almost zero after 15 minutes. Next I dropped pan, removed and checked screen, removed filter. Everything was very clean. Filter in the canister was a Hastings LF 101. Does anyone have any suggestion what I might try to do to correct this erratic pressure?
Thank you in advance
William Peets
06-20-2006 01:47:57
 Re: JD 435 with oil pressure problem in reply to cdm, 06-03-2006 17:52:30
I had the same but I don't think it was a big problem. Once the engine was rebuilt including a new oil pump the needle stays pegged. No noticeable differance in performance with new engine.
