G left brake grinds gears
Gwiz
06-03-2006 17:02:44
I just had my left brake out and cleaned it up. I had a lot of grease in it and didn't work very well. When it did, it would lock up with a loud thunk.
Now that I cleaned it up, I thought it was great. Soon after getting it back in, it started making gear grinding noises. Now, as soon as I touch the brake lever, it sounds awful. Doesn't sound like the outer brake drum, sound like terrible gear grinding in the transmission. Is there something inside the tranny that I did not get back together correctly when I slid the brake assembly back in?
James
Pappy
06-03-2006 19:42:55
 Re: G left brake grinds gears in reply to Gwiz, 06-03-2006 17:02:44
When you re-installed the brake assembly, there is nothing that won't fit right. Just the gear meshing into the bull gear. If your brake bands were greasy or oily, you have to get them clean. Use solvent and then dry them out. Put them in an oven or bar b que grill if you have to. Once all the grease is gone, more than likely they will work. The only other problem you might have is severly worn bushings in the brake assembly.
