1950 John Deere B
MoeGibo
06-03-2006 10:13:05
I have checked the timing on my B and it is correct but still i get pops and backfires. Does anyone know what the valve clearances are for a later Styled B? I appreciate all the help so far guys.
johnlobb
06-03-2006 20:28:31
 Re: 1950 John Deere B in reply to MoeGibo, 06-03-2006 10:13:05
I also have a 1950 B and the book says 0.020 (cold)
johns48b
06-03-2006 13:30:35
you didn't say if it was running when you parked it or not. was it sitting outside where somebody could have switched the plug wires around? have you done something to it that might cause it to miss. how long has it been since its had fresh gas in it? give us a little bit more to work on. thanks
MoeGibo
06-03-2006 13:39:24
 Re: 1950 John Deere B in reply to johns48b, 06-03-2006 13:30:35
The B was running when i parked it to do the head gasket. I put fresh gas in it since i had to drain the tank to remove it. I have checked time and set the valves now but havent had any good results. A gentleman suggested replacing the condensor so thats my next move. Any other suggestions are very much appreciated.
TommyT
06-03-2006 12:21:21
set at 0.020 (hot)
MoeGibo
06-03-2006 12:26:43
 Re: 1950 John Deere B in reply to TommyT, 06-03-2006 12:21:21
anyone have a cold setting for the valve clearance? cant check it hot if it wont run
Mike M
06-03-2006 20:47:47
 Re: 1950 John Deere B in reply to MoeGibo, 06-03-2006 12:26:43
.022 " cold
DP
06-03-2006 12:10:54
Try changing out the condenser on your rig. They are not too expensive, and will act that way sometimes. Don
moegibo
06-04-2006 11:52:21
 Re: 1950 John Deere B in reply to DP, 06-03-2006 12:10:54
i changed out my points and condensor and got the tractor to start i have to make a few adjustments on the carb since i rebuilt it but other than that seems to run fine. thank everyone for your help
