148 Loader problems
Phil3010D
06-02-2006 16:17:03
I recently replaced some hydraulic hoses on my 3010 tractor, I also slowed down the rate at which the loader lifts. Now for some reason the loader lowers a little bit when I move the control lever to lift. After it lowers it lifts up ok. With a load in the bucket the problem is noticably worse. If I have a load in the bucket and I lift it high, stop and then go to lift it higher it will drop a good 3 or 4 feet and then start lifting again. Any help would be appreciated.
Hayfarmer
06-03-2006 08:31:39
 Re: 148 Loader problems in reply to Phil3010D, 06-02-2006 16:17:03
I believe the other response is talking about an internal adjustment in the remote valve. As I remember there is a sort of "rocker" setup and they need to be adjusted using a dial indicator. Or the seats or valves could be worn a bit allowing oil to pass until there is a bigger opening. Slowing down the speed may have agrevated the problem so you noticed it. I have the same problem on the bucket cylinder of my JD430. Some external valves have internal load checks to prevent the oil moving through until there is enough pressure.
msb
06-02-2006 21:03:13
You slowed down the rate of operation? Intentionally? You must be using the original 3010 selective control valves?Not an independent valve?If your answers are yes then the selective control valve needs to be readjusted.The return vales are set too close.The other thought is all the trapped air hasn't gotten out of the system,but if you have used the loader for more than a few minutes, all the air should have been purged.Try extending and retracting the cylinders to both extremes a few times to be sure.
phil3010d
06-03-2006 07:29:16
 Re: 148 Loader problems in reply to msb, 06-02-2006 21:03:13
They are the original valves. By adjusting you mean increase the rate back up, or is there another adjustment your refering to? Thanks
