316 john deere electrial problem
irv
06-02-2006 11:52:16
I believe my 316 John deere mower has an electrial problem. Mower was running fine, parked and was totally dead when tried to restart. No juice anywhere except at the battery. Bypassed seat and neutral switches, replaced ignition switch. Still nothing. Getting juice from the battery. I am an electrial idiot. Any help appreciated, large lawn still growing. Thanks Irv
jeff314
06-04-2006 12:11:25
 Re: 316 john deere electrial problem in reply to irv, 06-02-2006 11:52:16
I have a 314 with the exact same issue...I have to charge the battery to start it and then as long as it is running all is fine. If I turn the PTO off in the middle of mowing the battery does not have enough juice to restart it. I turn the tractor off and just like yours, nothing! - I replaced the PTO switch already and made sure all connections are good. I am getting a new rectifier tomorrow, you could check yours, you should have about 11-13 volts from the middle post to ground when it is running. Mine is only putting out about 9 volts, not enough... Will let you know....
Pete/ME
06-03-2006 02:42:31
I'd check the new switch to make sure it isn't defective, then go over the wireing again-deadman, neutral, pto engauge. I don't know how far you've looked, but mice knawed some of my wireing which caused a dead stop.
Sam#3
06-02-2006 20:38:33
I don"t know your machine so I"m just green lighting here.
Do you have a wiring diagram? Have you ID"d all the safeties? They may have sneaked something new somewhere.
Exp. I have a Cub Cadet with reverse safty. I can"t back with the deck running. The neutral safety is actually on the brake pedal.
irv
06-03-2006 07:49:32
 Re: 316 john deere electrial problem in reply to Sam#3, 06-02-2006 20:38:33
Thanks for all the leads. Will be checking them all out. The longer the grass, the crankier the wife. Irv
johns48b
06-02-2006 15:37:20
if you had two fuses to blow did you find the cause then? if not that may be whats wrong now. if there is no fire coming out of the switch going no where else i'd say replace the switch. can you use a screw driver or jumper wire and touch the two post on the solenoid and make it turn over? connect a wire from the hot post to the small wire going to the solenoid and see if it turns over. if so i'd say its the switch, if not it could be your solenoid. maybe somebody else can tell you more in a while.
johns48b
06-02-2006 12:20:59
this may be something you've tried already but if not its worth the effort. try cleaning all you battery cable connections at the battery and at the ends where ever they attach. i've seen times on hot humid days that i've had to clean the terminals twice when i was out in the field with nothing to coat them with. i like using that white lube in a spray can to coat the ends with after they are clean and reattached. i keep all my battery stuff in a seperate tool box so if i need to work on a batery problem i can just pick it up and go. i just bought some cheap wrenches to keep in it and don't worry about them if they get acid on them. i also keep two different types of battery post cleaning tools in it and a tool to spread the ends of cables so they will come off easy. i keep some extra ends in it, a rag and a cheap dollar tool to pull the cabels off with if i can't spread the ends and get them off easy. hope this helps.
irv
06-02-2006 14:32:05
 Re: 316 john deere electrial problem in reply to johns48b, 06-02-2006 12:20:59
Sorry Johns48B. The terminals are clean and I get juice to the ignition switch. Also two fuses that have blown in the past, are OK. Thanks for the suggestion. Irv
Rick in Michigan
06-05-2006 12:50:41
 Re: 316 john deere electrial problem in reply to irv, 06-02-2006 14:32:05
The battery may be bad. Just because you are getting "power" from the battery doesn't mean it is enough to start the engine. Make sure you are getting at least 13 volts from the battery. Someone will probably chime in and add the fact that it is amperage that is needed, but I figure if you have at least 13 volts at the battery and clean the posts as suggested earlier there should be sufficient amperage...but then again, I've been wrong before!
