35B problem
Jak
06-02-2006 06:44:05
Have a B hand start giving difficulty starting,now she won't hit at all.I adjusted the valves last night and the two intake rocker arms were at least .050 or more out.Put it back together and won't hit a lick.I'll have to say out of all my experiences this has been the most aggrivating piece of &^%$ equipment I have attemped to work on.She has good spark,darn good compression(shoulders still hurting),and gas?????
Duane Larson
06-02-2006 11:10:02
 Re: 35B problem in reply to Jak, 06-02-2006 06:44:05
Jack,
A couple of additional thoughts to those given below. For sure drain the old gas out and put in fresh gas, and clean the sediment bowl. Then let the gas flow from the carb bowl drain to get the old gas out of the sump area below the fuel inlet. Pull the plugs and determine when the flywheel side piston is coming up on compression (blows air out of plug hole). Roll to line up mark on transmission case with L.H.Impulse mark on flywheel, then rotate flywheel about 125-135 deg further and at that point all rocker arms will be free. (That will be about 1/8 turn before LHExhaust mark lines up with transmission case mark). Loosen locknuts and hand snug adjusting screws until there is no movement in tappet levers, then back off adjusting screws 1/3 turn (two lobes on a 6-point nut) and lock the screw. That will give an accurate 0.020" clearance for each tappet. It can be hard to use a feeler gauge unless the lever and valve has been ground smooth.
Make sure spark is occurring at the proper time for each plug - this can be an issue depending on what magneto you have on the tractor.
Jak
06-02-2006 11:49:37
 Re: 35B problem in reply to Duane Larson, 06-02-2006 11:10:02
Wico X mag.Thanks
Ben.So.Tex.
06-02-2006 08:40:26
Try a fresh set of plugs, may have good spark out of the tractor and weak spark when under pressure.
Same for points.
My two pennies
Jak
06-02-2006 10:28:52
 Re: 35B problem in reply to Ben.So.Tex., 06-02-2006 08:40:26
We'll do that.His gas is yellow as can be,I think it is old,probably ought to drain it too and get some fresh in it.Thanks guys I'm about to pull my hair out.Jack
Ravgardner
06-02-2006 08:10:10
Check the air intake pipe for blockage from mouse or insect activity. No air = No start. Check for the fuel flow from the float bowl, by opening the pet cock and you should see a stead pencil lead size steam come out. If these are ok. Recheck your valve lash adjustment. Too loose is better than too tight. Too tight and the valves are held open. Next to check would be the timing.
Get back to us with your findings. We will get her going!!!!!
Jak
06-02-2006 10:26:32
 Re: 35B problem in reply to Ravgardner, 06-02-2006 08:10:10
Had a steady flow of fuel coming out of the carb bowl.Double checked the rocker arms but might check once more.I am going to unhook the carb/breather connection and see if she runs.I will check the timing.The left hand exaust open on the flywheel was lined up with the mark on the reduction gear cover and the left hand exaust valve wasn't open?????
Mike M
06-02-2006 07:44:48
I think it should be donated to my collection ASAP.
