310e 4x4 backhoe will not move forward (rev OK)
TVCasualty
06-01-2006 18:50:48
I feel like the ingrateful kid that only comes around when he needs something... but, I'm in a bind.
Using the neighbor's 310e 4x4 backhoe, and the other day, it stopped moving forward while I was pointed up a slight incline. I raised the bucket, then tilted it, and it took off. No more problems after that... until about a week later. I was pushing some trees (up a very small incline.. not more than a couple of degrees) and again, it stopped moving forward.
After checking the fluids and watching the neighbor adding some ATF, I still had nothing. Tore apart the control panel and cleaned up all the contacts for the relays, fuses, etc. Checked continuity on the FNR lever, and I can hear the relay click in both FWD & REV. It began moving forward again, but then I backed across a bump that let the tractor lilt to the right. Then it stopped going forward again.
The tractor moves fine in REV, but there's just no reaction in FWD at all.
I'm new to the whole backhoe thing, so I have no clue how the thing works. Is there a transmission filter that could be clogged and cause this behavior? Are there seperate pumps for the FWD and REV? Has anyone ever had this happen to them?
I've consulted the manual, but it was no help. Can't find anything online either - been googling the crap out of everything, but no luck.
Any ideas?
AllenC.
07-05-2006 20:08:54
 Re: 310e 4x4 backhoe will not move forward (rev OK in reply to TVCasualty, 06-01-2006 18:50:48
You might check the Forward electrical solenoid to see if you can hear it engage when you put it in foward gear. I don't know if a 310e is built like my 410D, but mine started blowing fuses when it was put in reverse. I found the reverse solenoid was worn to the point it was shorting-out. Installed a new one and it works fine now. You can find the 3-solenoids on the left side of the tractor (if you are sitting in the driver's seat). I had to take the middle hood off to get to mine. I was able to get to a part of it by crawling under the tractor and looking for the reverser. You really need a test manual to help you.
TVCasualty
06-03-2006 08:45:29
Just remembered - the neighbor added what appeared to be automotive ATF to the transmission when it quit moving forward. Can't imagine that this would prevent it from moving only in forward though. Still guessing that there are seperate pumps for FWD and REV, but they seem to work off of the same relay.
Anyone know where I could find a detailed electrical diagram or hydraulic diagram for the 310E?
Thanks,
Russ
