Amp Meter Wiring on 50 A
Soldner
06-01-2006 16:31:41
I need to rewire a 1950 A, and the tractor has no wiring at all.. I was wondering if someone could send me a picture of how the amp gauge was wired up, and if anyone has a wiring diagram, that'd be much appreciated. Thanks everyone.
John T
06-01-2006 19:54:06
 Re: Amp Meter Wiring on 50 A in reply to Soldner, 06-01-2006 16:31:41
Soldner, if youre still at the factory original Positive ground and ifffff f ???? the ammeter is labeled with + and - terminals (it may be and may not), on most ammeters the - would have BUT ONE wire attached, the main hot battery voltage supply feeder often fed from the big post at the starter where the big battery cable attaches to it. The other + terminal would feed alllll loads such as lights and ignition, usually via a wire from it to the BAT input terminal on the switch(es) PLUS it would wire to the BAT terminal on a Voltage Regulator or Cutout Relay.
NOTE if you used a 4 terminal VR however that has the LOAD terminal, then the loads like lights n ignition would be fed from the VR's LOAD terminal instead of the ammeters load side terminal as previously noted. STILL the ammeters LOAD side wires to BAT on the VR regardless.....
Just remember theres ONLY ONE wire on the ammeters voltge SUPPLY terminal, while the other LOAD terminal always wires to the BAT terminal on a VR or Cutout Relay PLUS feeds loads like lights n ignition UNLESS you have a 4 terminal VR with a LOAD terminal. Then if wired bass ackwards (ammeter reads backwards), simply do like Frank told ya and reverse the leads, piece of cake.
John T
F-I-T
06-01-2006 17:23:40
third party image
Soldner:
This is a pictorial style diagram out of the late "A" book, whcih should help you out. The important thing to remember is that there is a battery side of the ammeter and a load side. If you get the wires switched, no problem, the ammeter will just read backwards.
So, you'll want the battery side of the ammeter to get its power from the lead that runs from the starter cable. The other two wires attach to the other terminal. When correctly wired, turning on the lights with the engine stopped should make the ammeter show discharge. If it swings to the positive, you have the wires on the the wrong terminal. Just swap all of them and you'll be good to go.
Frank
Sodlner
06-01-2006 17:53:41
 Re: Amp Meter Wiring on 50 A in reply to F-I-T, 06-01-2006 17:23:40
Thanks so Much Frank.. That will work perfectly! Thanks again.
