JD 2010 and 45 combine engine
ArkyBass
06-01-2006 09:35:37
I have found a 45 combine engine for my 2010. I have heard that these are the same engines. My question is does it bolt right on?? Any other tips or tricks conserning this?
I have heard this much.The following parts on the 45 aren't the same and would have to come from a 2010:governor, waterpump, starter, flywheel & possibly the manifolds.
ArkyBass
06-02-2006 11:48:17
 Re: JD 2010 and 45 combine engine in reply to ArkyBass, 06-01-2006 09:35:37
Thanks for the repy..great info, I'm not sure how to tell which 145 he has?
The seller told me:
The block # on the gas engine in the 45 quareback is - Casting #T16277*T.
I'll check my block this weekend.
HTR
06-01-2006 17:00:18
HA145 and HB145 engines are parent bore engines. HC145 and newer engines are sleeve and deck engines, like the 2010 engine. All accessories will interchange and bolt, from any of the engines.
In addition to your list, at least, the front crankshaft pulley, and oil pan will have to be changed.
