JD 300 backhoe hits rear tires
Mark Thomas
06-01-2006 08:23:15
I've recently purchased a 1970 300 Industrial backhoe in decent shape. The unit only has 2880 hours on it. My question is, the rear tires are currently 16.9 X 24, but the specs call out a 17L X 24 which is even wider I beleive.
The rear tires currently "Hit" and rub on the backhoe frame severely. It looks like almost a .75-1.00 interference fit. I cannot see any way to move the E9250 backhoe rearward (For clearance)because it is bolted directly to the rear axle and E 7230 loader. Any ideas about what is going on? Frame all looks straight, tires hit evenly on both sides.
buickanddeere
06-01-2006 22:33:47
 Re: JD 300 backhoe hits rear tires in reply to Mark Thomas, 06-01-2006 08:23:15
Rubbing across the entire width of the tread or just along the sidewall and edge of tread? Had you tried reducing the tire pressure some? The 17L is a short little twert of low profile tire compared to the 16.9x24, being 3.0" less in dia. That might well be the issue
johns48b
06-01-2006 11:12:02
most rims have some type of dish to them. it sounds like some body put the tires on the rims on the wrong side. can you switch side with the rims? that would mean you have to flip the tires over too. also my ford has spacers built into the rims so you can put them either on the inside or outside of the dish part to make them wider or closer.
Mike M
06-01-2006 10:12:36
I looked around at the parts catalog at www.deere.com and your machine is listed there.
It should make more sense if you looked and compared which type of wheels you have as there are many.
There was an extension spacer offered # T22690 to make them stick out wider. Maybe this is what you are missing ??? or perhaps you have the wrong type of rims alltogether ?
