420 tractor info needed
Arthur
06-01-2006 03:50:49
Is the 420 12volt neg ground? Mine didn't come w/ a battery in it...Also, what are the torque specs on the piston rod end caps, and the head bolts...Need to get a set of manuals for this, but I am spending all my money on parts right now. Thanks for any help ....
johns48b
06-01-2006 05:24:23
 Re: 420 tractor info needed in reply to Arthur, 06-01-2006 03:50:49
i'd go on and get my manuals now. some parts guys don't like spending the time it takes to look up a bunch of parts, but if you get your parts manual and give them the part number they don't mind doing that. theres a site that list most pubs. it will give you the owners manual, the service manual and parts manual number. jd pubs telephone number is 1-800-522-7448. the site name is (as typed) JD Heritage
rick in sc
06-01-2006 04:01:39
Arthur, 6 volt positive ground from the factory. Head bolts 85-95 ft.-lbs. Valve clearance .015 cold. Rod nuts 55-65 ft.-lbs. Lock nuts on rod nuts 1/4-1/3 turn after contacting the rod nut. Good Luck!!!
