JD 5400 4X4 BLOWING OIL OUT THE EXHAUST
LYNN HOBBS
05-31-2006 21:03:49
My 5400 4x4 started blowing oil out the exhaust. I removed the Turbo and it appeared to have bad seals. No metal shavings on the intake yet. I replaced with a factory turbo and changed the oil and filters, but it is still blowing oil out of the exhaust. The motor appears to run fine. There doesn"t appear to be a lot of blow by if you remove the oil fill cap. Any one know what I might check next???
LYNN HOBBS
11-23-2006 11:54:00
 Re: JD 5400 4X4 BLOWING OIL OUT THE EXHAUST in reply to LYNN HOBBS, 05-31-2006 21:03:49
This ended up being a bad seal on a new Turbo. I replaced the original turbo after it lost a seal with a brand new Garrett just like the factory uses. The new Garrett came fro the factory with a bad seal and I just wouldn"t admit that is might be bad. After wasting many man hours. I decided to send it back to have it checked and it was a bad seal.
Lynn Hobbs
06-02-2006 04:22:33
To all who offered helpful comments I really appreciate you all. I have checked the drain back line, oil level and kept the filters changed regularly, also been running the required 15w-40 oil. I will check compression and check injectors. Thanks, Lynn Hobbs
Now for all you Smart a$$@$!!! I have always respected this forum. I have several older tractors that I still farm with and two which are collectors. As well as and old "R" which is in restoration stage. My blood has run green since I was born. There are not many places for farmers to get information on internet about their tractors. When you farm for a living you have to save every penny you can and not run to a dealership for every little thing. I work hard keeping my costs down and do and excellent job servicing my equipment instead of running around parades and tractor pulls to show off my antique tractor CALJIM!! So I would appreciate it if you keep comments to you Da@$ self. You arrogant turd!! People like you Ruin really good informational websites. As seeking information here again. I probably won't. I wish that you have a problem with one of your pieces of equipment and the replies you get are ones like you left me. Have A Nice Day:)!
G/MAN
06-01-2006 07:35:58
How many hours? Could be a fuel system problem, valve train problem or mechanical problem somewhere else. I'd remove the nozzles for testing and run a compression test. I'd also check and adjust the valve lash.
TylerARK
06-01-2006 06:02:08
Have you checked the oil drain back line from the turbo back to the block ?
Tyler
johns48b
06-01-2006 05:28:28
if you've been using ether to start it with this winter you may have broke a piston. more than likely its time for a set of rings.
buickanddeere
06-01-2006 04:04:20
Is the crankcase vent plugged? Is the oil level overfilled? Has to light an oil been used? It maynot be crankcase oil at all. The slobber maybe plugged injectors from age,wear and a dirty batch of fuel. Is there something plugged somehwere between the air intake and the intake manifold. A rich running engine will slobber. And too much restriction on the intake side of the turbo can fail the seals.
CalJim
05-31-2006 22:46:07
You might check something other than an
ANTIQUE TRACTOR forum..... .
G/MAN
06-01-2006 07:34:27
 Re: JD 5400 4X4 BLOWING OIL OUT THE EXHAUST in reply to CalJim, 05-31-2006 22:46:07
The same things that could cause a 60-year-old "R" to slobber oil can cause a 5400 to slobber oil.
Tx Jim
06-01-2006 03:09:35
CalJim,you need to ask Kim to add ANTIQUE to heading of this forum that states "dedicated to John Deere tractors" As for blowing oil out exhaust has the air cleaner been checked for obstructions? Tx Jim
