1010 Fuel Level Gauge - Ohm Readings
Osage
05-31-2006 18:54:21
Anybody happen to know what the Ohm readings should be coming out of the tank for "Empty" and "Full"?
Also who sell a replacement gauge?
Thanks in advance,
Osage
Glen in TX
06-01-2006 11:03:14
 Re: 1010 Fuel Level Gauge - Ohm Readings in reply to Osage, 05-31-2006 18:54:21
JD sells the guages. They either work or they don't. Take the sender out of tank after draining it down some and then ground it and move the float while watching to see if guage works. You can also use a variable potientometer rotary switch to test the guage as it works the same as a sender. If you get guage to work with potientometer but not with sender then you know sender is bad and can determine if guage is bad that way too.
