45 loader front cylinder pin removal tricks?
Fred from MO
05-31-2006 04:57:27
Does anyone know if there is a trick to removing the front cylinder pin on a 45 loader. This is the pin that holds the front of the cylinder to the loader framework up front where the loader stand legs go. I have the pin rotating, and have tried to drive it out toward the tractor (driving on the non threaded side), but they seem to be stuck. I don"t want to break anything.
Thanks
Mike M
05-31-2006 05:05:55
 Re: 45 loader front cylinder pin removal tricks? in reply to Fred from MO, 05-31-2006 04:57:27
They have a groove in them for holding the legs.
Did you remove the support legs yet ?????
Fred from MO
05-31-2006 14:44:41
 Re: 45 loader front cylinder pin removal tricks? in reply to Mike M, 05-31-2006 05:05:55
Yes there is a groove in them for the legs, and I have removed the legs.
I Bleed Green
05-31-2006 15:12:25
 Re: 45 loader front cylinder pin removal tricks? in reply to Fred from MO, 05-31-2006 14:44:41
Ok you have the legs off. The pin should come right out. The groove on one side and the handle nut on the other is the only thing holding the pin in the hole.
