4020 Loses Hydraulic Pressure When Turned Off
S.Thorsen
05-30-2006 19:00:28
With the tractor running the 4020 has hydraulic pressure for atleast 5 minutes, maybe longer. There is plent of lifting pressure. Here's the problem. When I turn off the tractor, it loses hydraulic pressure imediatly. Start the tractor back up and it takes close to twenty to thirty seconds before there is pressure for the steering, loader, or brakes.
Even if I start with my foot on the clutch,I get pressure. Never any chattering. Once I have pressure it is there until I shut tthe tractor off.
Anbody got any advice?
Mike M
05-31-2006 05:54:36
 Re: 4020 Loses Hydraulic Pressure When Turned Off in reply to S.Thorsen, 05-30-2006 19:00:28
You said that once you have pressure it's there until you shut it off.
I fail to see the problem as your pump can't pump when shut off ????
johns48b
05-31-2006 05:02:19
you didn't put the check valve on in the wrong direction did you? have you changed your hydraulic filter? if its about stopped up it might cause these problems i would think.
msb
05-30-2006 20:35:31
Need to know the serial number and the tramsmission type before anyone can offere any advice.
S. THorsen
05-30-2006 20:49:57
 Re: 4020 Loses Hydraulic Pressure When Turned Off in reply to msb, 05-30-2006 20:35:31
Sycorange 1967 I think.
We had the hydraulics rebuilt a check valve install on the side of the transmission. The differential lock value was leaking for a while if you stepped on the clutch you lost hydraulic pressure almost imediately. With the differential lock applied the problem went away. We were proud of finding this problem, and frustrated that the a new problem has developed.
Unfortunately,with all this previous work done, there is a possiblity that we have inadvertantly created the new problem.
