Deere LA
clifford davis
05-30-2006 18:22:08
My friend has an LA model JD, unsure of year model, that has needs some help. First thing is that the crankshaft has been turned 60 on the main bearings, and 40 on the rod bearings. Does anyone, make a set of 40 over rod bearings?
I also noticed that the rod bearings seem to be part of the rod end, as they will not come off easily like a car engine. I assume the bearings are Babbitt material poured on the rods and then machined. Does anyone know if this is correct?
If so, can I get the old bearing removed and the rod end and cap machined to accept a bearing insert?
Thanks, C.Davis
