301-A (1020 Ind.) Overheating
Dave Klever
05-30-2006 06:48:38
I have a 301-A gasser that is overheating. For utility work it is fine, but it will overheat when doing any sort of work requiring sustained RPM�s (e.g. bush hogging). If I keep the revs down around 1500 and keep the loads light I can keep the temperature under control, but beyond that the needle heads off toward the red.
At first I figured that my thermostat may have been bad, so I replaced that. While I was at it I replaced hoses and the fan belt, because they were all pretty well aged. Externally the radiator appears to be clear.
There is no apparent oil in the coolant or coolant in the oil.
I�m thinking that there must be something slowing the coolant flow. Next thing I�m considering is pulling the radiator and taking it to a shop for a thorough cleaning.
What about the water pump? Wouldn�t it be obvious if there was a problem with that? Never had one fail on me so I don�t know what happens if they do.
Any troubleshooting advice you all can give is appreciated. Thanks.
Tom in Central Pa.
05-30-2006 15:25:31
 Re: 301-A (1020 Ind.) Overheating in reply to Dave Klever, 05-30-2006 06:48:38
With flat-hub fan blades, it is easy to bolt the fan on backwards.
Most tractors of that size use a blade that draws air thru the radiator and back across the engine.
Check the rotation, and be sure the leading edge of the blade catches the air and forces it back.
Be sure yours is installed correctly. Otherwise it just "beats" the air without moving it.
johns48b
05-30-2006 09:41:49
i've had the impeller come lose on the shaft and slip on ford trucks. i would suspect the water pump if the tractor cranks easy.
ET
05-30-2006 09:19:13
It would be a good idea to boil out the radiator like you said. Have you checked the ignition timing? Late timing will make an engine run hot. It is posible for the fins on the water pump impeller to be rusted away but thats kind of rare.
